To:- Ben Neal, & Other Locomotive Builders in Trainz
Posted: Wed Jul 08, 2009 8:42 am
by Ethan Stone V&T Man
Ben,
Can you build the five Bodie & Benton Locomotives in trainz?? If you can here is the all the Info I Got.
Number Name Arrangement Builder Year Notes
1 - 0-6-0T Prescott Scott 1881 -
2 - 0-6-0T Prescott Scott 1881 -
Second
#2 Inyo 2-6-0 - - -
3 Mono 2-6-0 Baldwin Loco Works 1874 Ex. Eureka & Palisade RR No.2
4 Bodie 0-4-2T H. K. Porter, Inc 1882 -
Thanks So Much,
P.S. please write back on this forum if you respond Thanks again.
Re: To:- Ben Neal, & Other Locomotive Builders in Trainz
Posted: Wed Jul 08, 2009 10:37 pm
Looks like you might be able to reskin Ben's Elberton Air Line ng mogul to the "Mono" #3, "Inyo" #2, and "Tybo" #1?
I haven't seen any models that look remotely close to the 0-4-2 Porter, and I haven't seen pics of the 0-6-0 Prescott locos, so I have no idea what they look like....
Posted: Thu Jul 09, 2009 5:58 am
Pencie,
How can I reskin those locomotives? and I shall find out more info of the Tank type locomotive for you and Thanks Again.
Posted: Fri Jul 10, 2009 8:05 am
Which version of Trainz are you running? Different versions have different instructions.
Posted: Fri Jul 10, 2009 9:30 am
Version 2.6TRS 2006
Posted: Wed Jul 15, 2009 8:46 am
OK,
Go into CMP and click the item you want to reskin. Right click and clone it.
Next go to the clone right click and edit, edit in explorer. You should now see the folders, look for one called body then look for the largest .tga file. Open it up in an image editing program, such as The Gimp, Photoshop, Paint Shop Pro, or Paint .Net. Make your changes to the .tga file and save. Then commit it and then look for it in surveyor.
