Need some help removing the auto numbering system
I'm re-skinning some of Pencil's rolling stock and want to remove that auto numbering system. I know that the number 9 will print nothing and stop it while in the game but, when cloning the car, that doesn't work.
Is there a way to edit the config file to remove all instances of that function? I've played with it by deleting lines but haven't found the secret yet. :shock:
I've deleted all this but there's something else I'm missing.
extensions {
arn_data-124060 {
number_low "1000"
number_high "1999"
number_colour "9"
Thanks in advance... :)
also remove the effects section:
effects {
arn_g0 {
kind "attachment"
att "a.rng0"
default-mesh <kuid2:104722:2511038:2>
arn_g1 {
kind "attachment"
att "a.rng1"
as well as the script and class lines:
script "arn_wagon_b"
class "ARN_Wagon_Basic"
Sorry I haven't gotten back to you on this...
I've been fooling with this and haven't gotten it down yet. When I remove the above mentioned, I get a very blank config file that doesn't work anymore. I apparently don't know enough about it, yet.
I wanted to thank you anyway, though... :)
Do you have a copy of the V&T boxcars I did? Those don't have ARN, so you should be able to use the config and scripts from those as a base.
I'm sure I do. I see it's going to be a little more then I thought so I've put it off for now. I do understand what I have to do and that was one of my plans was to find a similar model to work with.
Thanks again, Curtis... :)
Pencil wrote:Do you have a copy of the V&T boxcars I did? Those don't have ARN, so you should be able to use the config and scripts from those as a base.
I guess I don't. :cry: I can't seem to find them anywhere. You gotta link to 'em?
They won't be released until Collin's V&T route, but I'll email you one this evening.
Oh, boy! I'm looking forward to this e-mail... :D
