I can't get my trainz pictures on to Imageshack and on to this website can you give me step by step instruction of to get them here, I will great fully appreate it
thanks
Problems
Re: Problems
I've never used Imageshack, but this thread on the main Auran forums may help?
http://forums.auran.com/trainz/showthread.php?t=3374
Re: Problems
Ethan
To get your photos on this forum is not hard. Many times you don't need Imageshack.
Here is an example:
Use your printkey to get the pic.
*1 - Save it to your desktop (or a chosen folder somewhere)
*2 - When you "reply" to a message or open a thread, just look below the big white space where
you type your message and you shall see two tabs.
"Options" and "Upload attachment"
*3 - Click on "Upload Attachment" and the instructions ask to get the filename.
You can retrieve it from your desktop files (or Imageshack) if you choose.
*4 - Where it says "Add the File" take a look up in the typing space and make sure the cursor
is blinking at the place you want the picture.
*5 - Then click "Add the file". It should appear in the proper space you chose.
Most of the time you can play with the controls to make the picture appear where you want.
Be sure of one thing - try to keep the picture below the 800 x 600 pixels if possible.
That's it for now. This should be enough to get started. Any more help, Just ask.
Here is an example:
