If you like it, can I upload it to the DLD?
You can register multiple versions under the same ID, and you can also create content using a particular ID that is equal to or less than the versions you have registered (if that makes sense)thegrindre wrote:Well, I'm still debating with myself on whether I should go with my new id or not, since everything I do from now on, will be under the new steamdrivre kuid number.
thegrindre is registered under a TRS2006 version which I lost, also and not sure if I can make content in '04 and use the '06 id. It's all very confusing.![]()
