thegrindre wrote:WOW! This is really great stuff but not for '04, huh?
Yeah, unfortunately, this function is only supported in '06 and later
bdaneal wrote:Just keep in mind that harp switchstands indicate the opposite of what you'd think (swing to the left, go on the right path; swing to right, go to left)
Yep, that's what I was figuring.  However, I saw a diagram of a harp switchstand yesterday that looked like it had another lever in the mechanism, so that the target would face the path of travel.  I don't know if that was ever built, or what the common configuration was; I'll need to look at prototype photos & see what they show, most likely.  (And yes, the silly arrows will go away
Col Hogan wrote: However, I have been very curious about the placement of the switchstand making sure it works proper each and every time. Once you make it's placement would you specify, somewhere close, as to where the switchstand should be??
The switch stand is built into the model, so it won't be able to be moved.  I might be able to script it so the user can pick which side of the tracks the stand is on, however.
When I get the switchstand in, I'll post a prototype for download, so you can see if the stand is in a good location.  I'll also post the gmax files, in case anyone wants to make narrow-gauge versions.
